Spirit V3.7.0 doesn't start on my Linux Mint 21.3
neifi
I've been working with Spirit V3.6.1 without problems.
With the new V3.7.0 the Spirit Settings Program doesn't start. If I start the program in a terminal, the terminal disappears and that's it.
For test reasons I downloaded V3.6.2, and this version also works without problems.
At around V3.6.0 I guess there has been a similar problem and the solution at that time was an adapted setting.sh file from Spirit.
Kind regards
toni
Thank you for the report.
We will test with the same distribution and make sure it will work there. Very likely on monday we will resolve it.
As temporary workaround please try do delete qt.conf file from the Spirit Settings directory.
neifi
After deleting qt.conf and starting the program, the Spirit Settings display appears but the left bar is completely empty (no symbols) and there are no background-frames in the right area.
If I press any of the above riders (General, Diagnose, Servos, ..) then the Settings Display disappears again.
Kind regards
toni
