Governot Spirit GTR
gerry
Use Spirit GTR with Jeti.
I have the following problem: If I switch to the workbench without ror blades at 1500RPM bailout and then turn it off again, the internal governor quickly starts up again as intended, but unfortunately it goes up to about 1900RPM. My question is this normal without rotor blades? I have not had this problem with other helicopters with the GTR so far.
Greetings Gernot
Checking RPM without rotor blades can be very inaccurate. So it does not make sense to measure it.
