Advice on low head speed setup (Gaui X7)
johncclayton
Hi
I want to put a Spirit on my Gaui X7. It's presently running Bavarian Demon. I am using a Kosmik ESC at 60% throttle with standard gears to achieve about 1560 head speed - which I enjoy greatly.
In putting a Spirit on a machine with low head speed - are there any settings I should change specifically to help with a low head speed setup?
John Clayton
John Clayton
Hi, you can play with Cyclic Gain, Elevator Filter (it shouldn't be too high) and if you will observe some bouncing then you can decrase Geometry 6°.
With these parametres it should be possible to tune it perfectly to any RPM.
