rescue direction
mett99
I am starting to do some inverted flying.
I was wondering if it is possible that after activating the rescue (Rescue Normal or Resue Automatic) the model from the inverted position will go to horizontal position via the roll/aileron axis.
Is there a position in the settings where you can define the direction of the rescue (first aileron and then Elevator)?
Thank you,
Edy
this is not possible to change, however we will make this adjustment available.
mett99
Is it already possible to know when this adjustment will be available?
Best regards
Edy
