Page 1 of 4
[SOLVED] Rp3-h elrs receiver. No telemetry values.
Posted: Sun 08. Sep 2024 21:02:43
by frisos@gmx.co.uk
I recently bought a Radiomaster rp3-h elrs receiver to work with my spirit gt unit. I connected it through the crsf connection. When discovering telemetry sensors, i get to see the spirit sensors in edge tx, but al the values stay at 0. I do get working telemetry from the sensors of the rp3-h itself though. I run elrs via the Ranger micro in my tx16s on Edge tx v2.10.2. My elrs firmware on the tx and rx are 3.4.3. On the Spirit gt i run firmware 3.7.0.
I would really like to have working telemetry from the Spirit unit as well and cannot find out what the problem seems to be…
Re: Rp3-h elrs receiver. No telemetry values.
Posted: Tue 10. Sep 2024 14:39:09
we received this receiver today and will check how it works. I will let you know soon. We will make sure telemetry will work properly for upcoming update (likely next week).
Posted: Tue 10. Sep 2024 19:19:27
by franz88
ZeXx86 wrote:Hello,
zexx86 please in the next update you can increase the numbers of flight style?
4 is too sweet and the 5 it's too fast.
Mybe add the decimal 4,1/4,2 ecc so we don't change the setup of the others
thanks
Posted: Wed 11. Sep 2024 7:10:58
by Habásek
franz88 wrote:
ZeXx86 wrote:Hello,
thanks
I think this setting has been in SW for several years and I would not change it.
Use expo in your transmitter.
I see the difference between 4-5 as very, very small.
Posted: Wed 11. Sep 2024 7:40:06
franz88 wrote:
ZeXx86 wrote:Hello,
thanks
Flight Style is not changing speed at all. The most pilots can't distinguish difference between 1 and 4. Can you describe what difference you can see or what you wish to achieve? Please do this in other thread, this thread is for different question.
Posted: Wed 25. Sep 2024 2:02:07
by underscore
I'm having the same problem: Using a BetaFPV ERLS Lite receiver (had one on my desk for testing, plan was to switch to RP3-H ultimately) running ELRS 3.5.
The transmitter discovers the following sensors: RxBt, Curr, Capa, Bat%. But the values never update (and I get the "sensor lost" warning).
Is there anything I can help debugging?
Posted: Thu 26. Sep 2024 5:43:08
Thank you for your report. Today we might finish required changes to make ELRS compatibility better.
We have the setup working with RP3-H now.
Anyone interested can write me a message to get faster access to the firmware update.
Posted: Fri 27. Sep 2024 9:47:17
The problem seems to be resolved completely.
Additionally we will have CRSF/ELRS integration fully working soon too.
Re: [SOLVED] Rp3-h elrs receiver. No telemetry values.
Posted: Mon 30. Sep 2024 10:34:33
by frisos@gmx.co.uk
Thats great news! Thank you for being so accessible to your customers! Looking forward to the integration too!
Posted: Mon 28. Oct 2024 9:24:02
by frisos@gmx.co.uk
Sadly flashing the spirit gt to 3.7.1 did nothing for my telemetry problem. Nothing changed. I've deleted all the sensors in the tx16s and re-discovered them. I get 3 sensors: esc amp, batt %, batt cap. But al values remain zero.
