Electric tail rotor
a20cae
Hi does anyone know where I can find out the setup info for an electric tail rotor as the current information is very sparse.
Heres what I have worked out so far for U spirit.
The swash all works fine its the tail set up and gyro.
I have Connected the 2nd ESC to Channel 4 (rudder)
Changed the setting in the software to enable the electric tail.
thats about it.
Does the U-spirit or the transmitter do the mixing.
no need to set anything else except Tail ESC range. This can be done in the Limits tab (PC Software).
You might need to set Rudder ESC Frequency - Servos tab, Rudder Delay, Pirouette Consistency - Advanced tab,.
Yes, Spirit will do all the required mixing.
