[ Version 3.7.1 released! ]
Posted: Fri 18. Oct 2024 14:33:07
New version 3.7.1 released!
  • Spirit RS and Spirit GTR units:
    • Support for external Spirit Wave Receivers.
    • From now you can connect external Wave Receiver such as Spirit RX7 and control model from a Wave radio.
    • You will need '''JETI Integration Cable''' for wiring at the RUD port + AIL pin.
  • Updated support for CRSF/ELRS telemetry:
    • Compatibility with Radiomaster ELRS receivers.
  • Throttle safety Locking feature:
    • You can Enable or Disable Throttle in the Spirit Settings to prevent Motor from spooling up accidently during configuration.
    • Bottom side of the Spirit Settings software has Throttle checkbox for enabling/disabling the motor.
    • Motor is reenabled automatically as soon as Throttle is set to Hold in case Throttle channel is High when closing the software.
    • The last settings is automatically saved so whenever software is started it can avoid a problems.
  • Setup Menus:
    • In case Throttle was High Setup Menus were turned off automatically with 3.7.0, this has changed now.
    • Spirit will not affect these menus anymore, instead Throttle can be Disabled with new Locking feature.
  • Receiver Changing:
    • Fixed a random error after changing between Receiver Type settings.
  • Setup Wizard:
    • Setup Wizard has Receiver Wiring schemes for Spirit W1 units.
    • Added possibility to set FPORT and CRSF with older Spirit units in the Setup Wizard.
  • Spirit RX protocol:
    • Support for OTA update for all Spirit units, except Spirit 1.
    • Firmware can be updated wirelessly directly from Spirit Wave radio starting from this firmware.
    • To enable the support firmware 3.7.1 must be flashed first with Spirit Settings software (together with Spirit RX firmware).
Update for the Spirit units is available in our Download section.
NOTE: No need to change any parameter after Update from 3.7.0 firmware.
