[SOLVED] YGE ESC connections to W1 - what adapters needed?
curmudgeon
I am planning on placing an order for a WAVE radio and a few W1 units. I plan to use YGE "T" series ESCs. What adapter(s) do I need to order to connect the YGE ESCs to the W1 unit so I can both obtain YGE ESC telemetry data as well as be able to program and adjust YGE ESC parameters via the WAVE radio?
wiring is identical to other Spirit units:
https://manual.spirit-system.com/index. ... _Telemetry
Except that with all YGEs you can do a full setup directly from Wave. Also no throttle range settings is needed, it will set up automatically.
curmudgeon
Awesome!! I like that the YGE telemetry and programming will use just the small JST-XH side port of the W1 and not need to use a port on the servo power rail which I need for other components. This is very good news. Thank you.
