Where is the Link in the Online-Manual to FrSky-FBUS ?
Hello Tomas,
I miss the link in the Online-Manual to the FBUS-Connection (FrSky) for GT-Units and in special the other units as Spirit Pro and Spirit II with additional modyfied FrSky Integration cable the only hint is made to FPort and not to FBUS - Can this please be corrected?
Thanks in advance !
You can only find by chance an hint, but not directly in the manual and that is not particularly helpful -
https://manual.spirit-system.com/index. ... FrSky_FBUS
Best Regards
Additional Information:
In Spirit Setting Wizard does the problem also exist, look at this:
That will be shown if you klick at the link:
please fix that too, there is also no information !
Matthias
Helihello
And while we're at it, may I suggest to also include a link to the UNI firmware for Frsky receivers, which solves all the issues which should have been solved by Frsky in the first place but where Frsky couldn't be bothered ... :oops:
Flying: OMPHOBBY M2 EVO, Futaba S-FHSS receiver.
Building: SAB RAW 500, YGE Saphir 125 v1, Scorpion HK5 4020-850KV, MKS HV9767 cyclic, MKS 9780 tail, Spirit GT, Spirit Geolink v2, Frsky R-XSR with UNI firmware.
Radio: Radiomaster TX16S II Max.
Thank you for your message. We fixed the manual link and it should work well now.
Hello Tomas,
in the spirit settings it works, perfect, thanks a lot !
But in the Online Manual 3.71 there is no link to FrSky-FBUS -
Please can you add this also to the Online-Manual ? There is no hint to FBUS...
Thanks in advance !
Best regards
Matthias
