Spirit Wave Trainer
Amatrix
I have just tried to test the Trainer Mode with 2 Spirit Wave. The transmitters connect, but unless a wild servo twitches, it doesn't work, is it not available yet? I also couldn't find out where I could define the button for the handover.
Another little note: CH0 and Aux have them assigned via PC and also work. This is called K0 and Aux2 via wave, if you select the function does not work, it only works again after confirmation via PC software.
I would like to ask you for help again, thank you for the fast delivery of the antennas. The installation worked without any problems. Thank you very much, LG Alex
Wave Trainer will be reworked little bit within following days.
I recommend to wait, because new options will be available there too.
We will check AUX2/CH0 functions.
