YGE Aureus 135 HV and RPM problem
Renzo
Hallo
All work well
but rpm do not work correctly
I have 1000RPM on the head but on display i see 15RPM
spirit Wave
spirit unit W1
what can be?
best regards Renzo
you likely set Gear Ratio at both ESC and Spirit.
So Gear calculation is done twice times.
Please set ESC to default gear ratio, then all will be ok.
Renzo
Yes you have right
same Parameter on the ESC and on the Wave...Parameter on the ESC at standard...and the RPM is right
tank you
