I am trying to setup my geolink so that "position hold" and "altitude hold" are invoked at the same time with the same switch. They are programed on channels 9 and 10 and a single switch. With the switch off, Position Hold is inactive, but the Altitude Hold is still active and labeled as active (fixed pitch). With the switch in the "on" position, Position Hold is shown as active as well as the Altitude Hold which is now labeled as active (pitch control).
I can not seem to find a way to have the Altitude hold off, when the switch is off.
Something happening I don't understand - any help?
GeoLink setup
Think I figured it out. Alt Hold seems to be expecting a three position switch with "off" being in the middle. I changed the switch characteristics (Jedi DS12 transmitter) to be 0% in the off position (instead of -100%) and 100% in the on position. Appears to now work as I intended.
