Voodoo bounce by fly looping
Voodoo2
when i fly a looping with my voodoo600 (HT Ninja Blades) it always happend that in the first section 0-30° the voodoo make a jump to 90°. I don t know if this is call bouncing.
Its like a heavy gust of wind.
I try elevator filter (value 2) but nothing happend (the first value was 0). Shall I increase to 4 or is there any other value to change?
Regards Jens
mostly this phenomenon is caused when there is not necessary cyclic pitch available. As the solution I recommend to configure Cyclic Ring - Aileron / Elevator range as high as mechanically possible without any binding. Alternatively you may try to decrease collective pitch.
Elevator Filter is not intended for the issue, so you can keep at the previous value.
