Govenor Problem XICOY X45H
Amatrix
Hello, I'm having problems getting my Xicoy X45H and the Govenor to work. Could you please look at the files. The Govenor goes to the right speed but then slowly runs higher and higher. A Spirit speed sensor with magnet 1 piece is installed. The speed controller shows a speed of 760 revolutions when idling, but with Govenor it says about 220. I don't know whether that could be the problem and how I could change it. Thank you for your support.
Lg Alex
Archiv.zip
(3.22 KiB) Downloaded 114 times
when you start the motor, please make sure to set Throttle Curve to a Flat for idling and also for flying.
Do not use a normal curve to manually spool up the engine but let the Spirit Governor to do this.
I saw your Governor is disabled for Bank 1 and Bank 2, this will cause problems. Please enable it for all Banks. I also recommend to set slower spoolup rate for this engine (to be safer).
Amatrix
Thank you for your answer. I actually only used Bank 0 with the flight condition. And I used Bank 1 for the start sequence. Is there a better option for the turbine to briefly start up the 100% Show. Otherwise I would have to wait until the Gov slowly runs to 100% and then switch it back to idle again. If that's the case, I can simply deactivate the bank. Sorry for the many questions, but I don't have the idea. LG Alex
