[ Version 3.7.2 released! ]
New version 3.7.2 released!
  • New Sensor Filtration for Spirit GT/GTR/W1:
    • Added new Motion Sensor Filtration algorithm for improved latency and better flight performance.
    • See the new parameter in the Expert settings.
  • New Stabi/Rescue Algorithm parameter:
    • Both Stabi Correction and Signal Processing parameters were replaced with a single parameter called Stabi/Rescue Algorithm.
    • Stabi Correction enabled correspond to option called High Precision.
    • Signal Processing enabled correspond to option called High Immunity.
    • This new parameter allows easier adjustment of the Stabi/Rescue behavior suitable for all models. It is recommended to use Standard option with the most models.
  • Setup Wizard:
    • Setup Wizard has updated Model presets.
    • New Model preset for XLPower Specter v2.
  • Gyro Rate mode:
    • Rudder will rotate faster with the same settings for Rate mode by 33%.
  • Rudder - Revomix:
    • Default Value changed to 1 from 0 allowing easier tuning for beginners.
  • Spirit 2 and Spirit Pro units:
    • Fixed bug with Tail being locked at one side with certain receiver types + telemetry combination.
  • Spirit GT:
    • Fixed bug with 4 servo with certain receiver types + telemetry combination.
  • Futaba SBUS2 protocol:
    • Reduced load for Telemetry processing.
  • CRSF/ELRS protocol:
    • Channel calibration during initialization changed to improve compatibility with ELRS.
  • ESC XDFly and ZTW telemetry support:
    • XDFly and ZTW are officially supported - previously it was working with OMP M4 telemetry option.
    • Wiring is identical as with OMP ESCs.
  • OMP telemetry protocol:
    • Current Battery measurement was fixed.
  • Spirit Settings software:
    • Fixed instability when connecting with firmware version 2.X or older.
Update for the Spirit units is available in our Download section.
NOTE: Please check settings for the new Stabi/Rescue Algorithm after update.
