Spirit RS with external BEC and switchable PowerBackup
Manni
I bought a second-hand heli with a Kontronik Jive 100 and an external BEC. As receiver with FBL I want to install a Spirit RS. I also want to install a switchable PowerBackup.
Is the following wiring with the Spirit RS correct:
a) Master cable from the Kontronik Jive (red wire disconnected): THR
b) First output cable from the external BEC (with y-cable): AUX
c) Second output cable from the external BEC: E1
d) Switchable PowerBackup (with y-cable): AUX
Telemetry shall be realised with the SAT1-Port.
Thank you for your support
Manny greetings
Manni
Wiring looks good, I believe it will be good.
Manni
Thank you for the quick answer!
Many Greetings
Manni
