I want to use the Telem UNI cable by Spirit to connect my Kontronik Jive with my Spirit RS for telemetry.
For the use of the cable for the Kontronik Jive the Wiki-Manual states: "It is necessary to modify the cable! Swap the orange and the red wires in the servo connector of the Telem UNI cable. The orange wire must be in the middle.".
But my new ordered Telem UNI cable has no red wire. There are only two wires: a yellow one (perhaps orange) and a brown one. None of these wires is in the middle of the servo connector.
Can I still use this cable and do I have to put the yellow (orange) wire in the middle of the servo connector perhaps?
Thank you for your help.
Manny greetings
Manni
Telem UNI cable by Spirit; Wiki-Manual unclear
SpUDmONSTeR
With the classic Jive, not with the Pro version, the yellow/orange cable must be plugged into the center because otherwise the satellite input of the Spirit will be damaged. The Jive outputs the power at the telemetry port on the outer port and not in the middle like most controllers
