Spirit 2 and Frsky TD MX Telemetry
Storchy
I have Frsky Ethos 1.6.1 with the Receiver TD-MX.
The Spirit 2 has no posibility to use F-Port.
So i configured the Receiver to S-BUS.
I configured the Spirit 2 to Futaba S-BUS.
I pluged the SBus out cable from the receiver to the RUD signal Pin.
I connect the SAT2 port to the blue YGE ESC Data cable without the red pin.
I get a connection to the Spirit 2 and the servos are working.
Everything works fine so far.
Next step is the Telemetry.
How can i get the telemetry from the Geolink and the YGE ESC.
Do i need the Frsky integration cable?
How to wire this cable,
I need help.
Thanks a lot
Spirit 2 has support for FPort and FBus, but you will need FrSky integration cable.
Also for SPort this cable is needed, however with EthOS you can get also full integration when using FPort and FBus.
Storchy
Thanks a lot for your fast reply.
I will try.
One more question to the wiring.
The signal pin from the black short cable side from the Frsky integration cable has to connect to the SBusOut or S.Port from the TD-MX.
Perhaps i have made a mistake the integration cable gets very very hot so perhaps it is dead.
I will buy a new one.
Thanks a lot
Storchy
Today i get the new FrSky Integration cable. This one is not getting hot!
I connect it to the black short side to F-Port Pin of the TD MX and the red side to Rud and the middle red cable to AIL Signal-Pin.
Everything works perfect.
I get the telemetry from the Geolink and from YGE ESC
Thanks a lot for your help and for the very fast delivering of the new cable.
Bye
Jörg
