Spirit W1 with SRXL2 connection diagram ?
PatrickN
Dear all,
I tried my best, looked in most places but did not find a satisfiable answer.
I want to get a Spirit W1 but initially use it with a Spektrum AR6610 / SRXL2 receiver and be able to switch later to the Wave.
There is a single line in the manual indicating that the X pin it so be used for external receivers.
Is this pin to be used to use an external SRXL2 receiver ?. Based on above information it's a bit limited to make the decision for the W1. I'm looking for a connection schematic. The reference to the GT's for external receivers does not give the correct labels that are used on the W1.
Feedback appreciated.
Many thanks,
Patrick
yes, you are right. Pins are compatible with Spirit GT so the wiring is identical (altough pin labels are different).
It will work with SRXL2 receivers, including SRXL2 satellites.
We have same AR6610T receiver here for testing, so I can help if needed.
PatrickN
Excellent, thanks, that's what I needed to know. Your quick support is appreciated.
With 2 GT's in the air, I am familiar with most basics :)
