Spirit Wave Delta Function
Amatrix
Good Morning Tomas
First of all, thank you for the great update.
Unfortunately, the Delta Function still lacks the option to turn the rudder height.
The current revolution only accesses the ailerons, it would be possible to add another point.
Revolution height / Revolution ailerons.
The option for dual rate and limit can be set separately would also be great.
LG Alex
Amatrix
Hello Tomas
The Delta now works perfectly, I still have one. I would like to set the height rudder a little high for the hand start using the switch. I tried the mixer function, but unfortunately to no avail. Do you have any tips?
I also wanted to mix the flaps with height on another model, but unfortunately I can only delay the flaps but not the height.
I would be grateful for your help, Kind regards, Alex
thank you for your info.
Can you describe what do you mean by height rudder please?
I am not sure what do you wish to achieve.
Hello Tomas,
I think he want's to say elevator ("height rudder" in German "Höhenruder" =height rudder)
Best regards
Amatrix
I launch the delta from my hand. I would add a base height for the takeoff using a switch.
on another model
On the jet I programmed the flaps and with a 3 second delay they slowly move to the correct position.
I would like to mix the height in with this. This also works, but unfortunately not with a delay. Would it be possible to add the option to set a delay to the mixer function.
excuse me I translate with Google
LG Alex
