Spirit pro 450 heli flips over on take off.
Posted: Tue 04. Mar 2025 14:43:42
by a20cae
Everything works fine tail holds swash all working in the correct direction.
software v3.6.2
When I lift off once in the air the heli flips volently to the right into the ground.
When I got the heli back to the house I noticed that if you lean the helicoter over (sytem live) it does not move the swash in the same direction as all my other spirit units.
I have reflashed the firmware, and reset the unit.
still does the same thing.
any ideas it all seams fine when plug into the PC.
Re: Spirit pro 450 heli flips over on take off.
Posted: Tue 04. Mar 2025 21:38:28
this problem is unfortunately caused by a wrong swashplate correction direction.
This can be caused by:
a) Wrong Mounting Position
b) Wrong Swashplate Type
c) Wrong Servo Wiring
d) Wrong Servo Reversing in the Servos tab
Or mix of all these 4 points.
So it is important to verify each and from then it should be all fine.
The most common is point c + d at the same time.
