GeoLink Altitude Limit Zero
Scott Howard
In the menus where you set the altitude for individual functions such as “Return to Home” and “Altitude Limit”, what sets the altitude zero? The point of spool up?
I fly at multiple locations at different elevations.
Scott
Hello Scott,
you can set altitude for Return to Home altitude at the Aid tab. Same for Altitude Limit. These altitudes are separated.
By default Altitude Limit is using altitude set during flying - froim the moment when you are engaging it. This is recommended way. You do not have to set it differently for other flying fields, instead you can set/change it at any moment.
