[ Spirit Aero 1.8.0 released! ]
Check out the news about the Spirit Aero.
Version 1.8.0 - ChangeLog:
It brings many new features and improvements:
  • Spirit Wave support:
    • Full support for Spirit Wave, Spirit W1 and Spirit RX7 devices.
    • For full integration with Spirit Wave use the latest 1.0.21 Wave firmware.
  • Support for separate Limits for each Servo:
    • Each servo can be configured separately allowing unequal throws for doubled servos.
  • Support for 6 Servos:
    • From now Spirit units allow to connect also secondary Rudder Servo with AUX/AUX2 port.
  • Support for 760us Neutral Pulse Servos:
    • All Spirit units can utilize Servos running at 760us.
  • New Smoothing Factor for Stabi/Rescue modes:
    • All transitions between modes (engaging/disengaging) can be smoothened to prevent excess stress.
    • Use Smoothing Factor parameter available at the Stabi tab.
  • New Spektrum Avian ESC telemetry support:
    • Full support for Spektrum Avian ESC telemetry.
    • Spirit GT, Spirit GTR, Spirit W1 are supported.
    • See wiring and settings at the Wiki page.
  • Full support for CRSF/ELRS telemetry:
    • Spirit units are able to send telemetry now.
    • Available sensors are:
      • Battery Voltage
      • Battery Current
      • Used Capacity
      • Vibration Level
      • GPS Latitude
      • GPS Longitude
      • GPS Speed
      • BEC Voltage (reported as GPS Heading)
      • GPS Satellites
      • Altitude
  • Graupner HoTT telemetry:
    • Spirit units will accept telemetry from Graupner HoTT ESCs configured as GAM, EAM and ESC sensors.
    • Previously only EAM sensor was supported.
  • UniSense-e telemetry support:
    • Spirit units will accept telemetry from UniSense module configured as Graupner HoTT now.
    • Using HoTT ESC will give you the most telemetry variables.
  • FrSky F.BUS protocol:
    • MicroSpirit units can use F.BUS protocol with FrSky integration cable.
    • FrSky Integration cable for microSpirit is recommended.
  • Added new protocol JR XBUS mode A:
    • Brand new protocol for native support of JR XBUS receivers.
    • Telemetry support will be availble in next updates.
  • ESC telemetry in the Spirit Aero software:
    • Spirit Aero software can display ESC telemetry values directly in the software now - Advanced/ESC Telemetry window.
    • All telemetry enabled ESCs can be interfaced with Spirit units also with Radio System that has no telemetry support.
  • New OMP/ZTW ESC telemetry support:
    • Full support for OMP Hobby, ZTW and compatible ESC telemetry.
Update for the Spirit units is available in our Download section.
WARNING: New limit settings is required after updating!
