Ailerons, Elevators, and Hovering Behaviors
davehour
Installed Aero 1.8.0. !
Very nice and useful changes.
I found some behaviors I would like to share for your evaluation.
1. When operating the elevators to maximum deflection in the up position, the elevator connected to CH0 starts moving first when the stick is released gradually. This happens with the gain set at zero.
2. When the hovering stabilization is activated, the rudder start to oscillate very fast. This happens with the gain set at 50%.
3. When operating the ailerons to maximum deflection, and the stick is released, gradually, the up aileron start moving before the down one. This is with the gain set at zero.
Videos attached.
IMG_3930.mov
Elevators Behavior
(12 MiB) Downloaded 6257 times
IMG_3928.mov
Hovering Behavior
(3.65 MiB) Downloaded 6363 times
IMG_3929.mov
Ailerons Behavior
(18.57 MiB) Downloaded 6281 times
davehour
System information:
-Savox 2273 servos
-Frequency set at 300Hz
-Operating at 8.4V
-Spirit Pro
Netopyr
I flew the 180. Can you please see how your Smoothing Factor is set? It works in both rescue and stabi mode.
Netopyr
XL V2 700, Devil 380, Spirit GTR, Spirit W1, Sir Edmunt Race, Pogo, Bublinky, Wave, DS 12 a NETOPÝR
davehour
The smoothing factor is set at 5.
Tested at 0 and 10, and the behavior didn’t change.
davehour
I noticed the ailerons and elevators behavior is correct under specific input channels percentages (Input channels in the Diagnostic tab):
Ailerons work fine up to 80% of input with the gyro gain set at 0%.
Ailerons work fine up to 45% of input with the gyro gain set at 52%.
Elevators work fine up to 85% of input with the gyro gain set at 0%.
Elevators works fine up to 45% of input with the gyro gain set at 52%.
