Spirit Wave with Airplane Questions
Posted: Wed 26. Mar 2025 20:15:12
by Amatrix
Hello Thomas,
I want to be able to switch -100, 0, +100 / 0, +100, -100 on a switch is that possible? Unfortunately, I didn't figure out how to change that.
I'm attaching another video to you, I have the problem when I switch the flight conditions with, for example, more dual rate or expo. It switches but it has delays on the servos. The whole thing runs on a PowerBox soft. I only connected the receiver RX7 to Sbus. Is this another bug or what do you think?
Thank you in advance LG Alex
Re: Spirit Wave with Airplane Questions
Posted: Fri 28. Mar 2025 10:21:52
by Amatrix
Hello Tomas,
Yesterday I thought about the channels.
Wouldn't it be possible for you to have access to the curve with every channel on the last page, instead of just Expo and deceleration, like with the engine.
Then you could easily implement complex settings.
As described above, create a V Curve 0 -100 + 100 or create a curve for brakes.
I know this from PowerBox System but my goal is to use all models with one transmitter.
And I really love the wave so far.
LG Alex
Posted: Wed 09. Apr 2025 16:27:29
by Amatrix
Hello Tomas,
I have another mini jet equipped with RX7, all servos are connected directly to the RX7, unfortunately there are the same delays.
Do you already have this on your list to correct or should I make you a video?
Unfortunately you can't fly like that.
I also see the problem that I want to set 12mm +/- for example when the height is high and on the aileron 8mm +/-
Unfortunately, this is currently not possible to limit the ailerons separately.
I would be grateful for a short feedback.
LG Alex
Posted: Sun 13. Apr 2025 6:30:37
Next update will allow configuring curve for each channel. Thank you for patience!
Posted: Sun 13. Apr 2025 10:05:58
by Amatrix
Hello Tomas,
Thank you for your effort, it's remarkable how great you make the system.
LG Alex
