Issue Flashing a WiFi Link to v3.7.2
davehour
Flashed a green board WiFi link to v3.7.2 several times and always ended with error but tested it and worked fine, and it shows v3.7.2.
Please advise.
davehour
Well, got frustrated of the issues these old, first generation WiFi links have (connection problems while using, disconnections for no reason, not able to connect and now errors flashing them), ordered two new WiFi Links V2.
the error could appear when computer disconnects from the Wifi-Link network and does not reconnect to it automatically. Instead it will connect to your home network. From then it can't check that flashing was done correctly and could show the error.
Regarding connection problems please note old Wifi-Links can't work reliably with more recent units such as Spirit 2, GT, etc. It was designed for microSpirit, Spirit Pro and Spirit 1. To make it working correctly with more recent units the module require hardware modification.
davehour
I’m using them with Spirit Pro’s, but they are very old and there has been a lot of changes since.
Thanks for the explanation of the flashing error.
