RPH-3 ELRS unstable?
flo
i just switched from spektrum to Radiomaster ELRS. So far so good but with the spirit i dind´t get it stable working.
First:
Channel Order does not match between my TX and the Spirit. Radiomaster uses AETR (1234) as default.
But Spirit Settings always shows my channels 3124. Is this normal?
I checked the order with betaflight or inav. there it is as expected 1234 (AETR)
Second:
ESC Telemetry is not working. Still waiting for the update
Third:
I sometimes loss my link between the receveiver and the spirit unit.
It started the first time when i opend the log in spirit settings. (could replicate it twice - but not any longer)
2nd time when i changed the telemtrie of the ESC (could replicate it)
When i disconnect and reconnect the receiver i get a link again.
The receiver show a solid red LED and i get Telemtry from the receiver antennas. But i don´t get any input into the spirit
Fourth:
My elevator channel was one time not centered. it show ~ +18% while the stick and the chnnale output of the transmitter was centered.
Unit is a spirit GT.
Software 3.7.3-r2
Any ideas
Is this unstalbe connection while connected with spirit settings normal?
best regards
Florian
frisos@gmx.co.uk
I have this problem as well. The unit failsaves often when connected to spirit link software. I get receiver lost errors in the log. Also when powering up on the field half of the times i don't get sticks and have to power up again.
channel order is correct. Please leave it at default at both Spirit side and Receiver. It will work out of the box.
Regarding telemetry and stability, we will release new update today that should fix it all.
If you are interested you can send serial number of your Spirit unit in a private message. We can assign it to your unit.
