SUNNYSKY X300A HV SBEC + Backup Cap to Spirit2
Posted: Tue 22. Apr 2025 18:21:41
by nmsantarelli
Good morning to all of the forum,
in the Spirit2 manual it is specified to use the two BEC outputs for models like mine which is a 700.
Checking the connectors coming out of the "SUNNYSKY X300A HV SBEC" there are two cables such as:
"Throttle/+/ -"
"RPM/+/-"
At the moment I have only connected "Throttle/+/ -".
Question:
Can the second connector "RPM/+/-" be inserted in AUX2 or do I have to isolate the yellow RPM cable and connect only "+/-" in AUX2?
I should also connect a "Backup Capacitor", in which port can I connect it?
To summarize the current connections are:
AIL pin -> SRXL2 adapter -> SPM4651T
RUD +/- -> SRXL2 adapter -> SPM4651T
AUX1 T/+/- -> Throttle from ESC
AUX2 ?/+/- -> Additional power from ESC
Ch1,2,3,4 -> Servos
Sys port -> only for interface
Thank you in advance for any help.
Re: SUNNYSKY X300A HV SBEC + Backup Cap to Spirit2
Posted: Tue 22. Apr 2025 18:45:04
by Mona
Manual says RPM signal on Spirit 2 goes on "PIT pin - pin in the middle of ELE/PIT/AIL port".
Connecting RPM signal to AUX2 won't do anything, won't hurt anything either. Just never connect power to ELE/PIT/AIL or SYS ports (the outer ones). Depending on receiver (if it runs off BEC power and has extra ports with a common power rail) capacitor pack can also be connected to a free receiver channel (don't think yours qualifies). Alternatively y-cable on BEC power should work.
Posted: Thu 24. Apr 2025 2:50:47
by nmsantarelli
Mona wrote:Manual says RPM signal on Spirit 2 goes on "PIT pin - pin in the middle of ELE/PIT/AIL port".
ok thanks for the thought
