[ Version 3.7.4 released! ]
Posted: Wed 07. May 2025 11:36:26
New version 3.7.4 released!
  • CRSF/ELRS Integration:
    • All CRSF/ELRS enabled radios can utilize native integration and telemetry support!
    • Spirit parameters can be easily configured directly from your CRSF/ELRS radio.
    • Telemetry is working properly with all ELRS receivers now.
    • Integration menu available at the Crossfire configure menu.
    • No Lua scripts are needed.
  • CRSF/ELRS Telemetry:
    • Telemetry contains new variable VSpd displaying RPM - Headspeed.
  • CRSF/ELRS Wiring:
    • Wiring for Spirit 2 units require to use the SYS port. Old wiring can be still used, but telemetry support is limited.
    • Wiring for Spirit GT units require to swap RX/TX pins from the previously used.
    • For wiring details please visit Wiki pages.
  • Spirit Settings software:
    • Crossfire CRSF receiver type name was changed to ELRS/CRSF.
    • ESC Telemetry in the software - Advanced - ESC Setup will display Headspeed using configured Gear Ratio and Sensing Divider.
  • Spirit Governor:
    • Default Governor Response value is 7.
    • Default Holding Performance value is 7.
Update for the Spirit Settings is available in our Download section.
NOTE: No need to change any settings after the update.
