I have a Spirit GT that is updated to 3.7.4. There are two Frsky RS Plus receivers, connected SBus In and Out. The connection to the GT is FBUS, using the rudder port.
In the transmitter, Ethos was just updated to 1.6.2 in an X20S. The two receivers were also updated.
Telemetry is working well, but there is an error message on the transmitter whenever the lua script is run for Spirit.
Under Info, the error is listed as a time stamp, followed by ?:-1method 'enable' is not callable ( a nil value)
I can reset the error, and it clears. Once the lua script is opened, the error returns. I have been unable to determine which specific value may be causing the error, and am hoping there is a means to do so. Otherwise, what would be the best method to follow?
