GeoFence the map method; which has Priority?
TrueBuild
Say I create a GeoFence for a location I fly regularly at and by error, add a take off location, and but put my heli in a different take off location; which takes precedence/priority return to home via GeoLink or Mode (4) ?
In short:- does the heli land at the take off spot or the GeoFence location?
I have just re-read Admin ZeXx86 comment in thread "geolink return to home" ;
Section 1.3 Modes, 1.3.1 On (1)
"Channel value 57% - 100% : When On (1) is displayed it mean that at this point Return to Home is engaged and model will move to the Home spot."
So is this the Home spot that is marked on the GeoFence map.
And...
Section 1.3 Modes, 1.3.4 On (4)
"Channel value 27% - 56% : When On (4) is displayed it mean that at this point Return to Home is engaged and model will move to your Take-Off position. Take-Off position is programmed automatically during each Take-Off."
So this the Take-Off position that is used if On (4) is used.
All makes sense now...
Command On (1) land at GeoFence map location.
Command On (4) land at Take-Off location.
It is a good idea to set the home position using the channel before each start at a given location.
Then you will be sure that the takeoff and landing point are the same.
TrueBuild
Habásek wrote:It is a good idea to set the home position using the channel before each start at a given location.
Hmm... I would rather, the landing spot be the take-off spot be assigned automatically via mode (4) because, the pilot does not have to remember to set anything.
That's why every time I take off for the first time, I save the return home position and I'm sure.
1.3.3 On (3)
Channel value -61% - -38% : When On (3) is displayed the unit is in a programming mode which allow to overwrite current Home spot to the new with position at which the model currently is.
TrueBuild
Habásek wrote:That's why every time I take off for the first time, I save the return home position and I'm sure.
1.3.3 On (3)
I'm interested in the term "When On (3) is displayed".
Is your transmitter a Spirit transmitter?
And does the transmitter actually display "On (3)" ?
