How do I remove a GeoLink RTH location from the map
TrueBuild
I've not been able to remove a GeoLink return to home location using the Set option.
What I mean is I cannot clear what is in that box; it keeps coming back.
I would like to remove that option and rely on the Mode (4) option. How do I remove GeoLink Landing location and keep the GeoFence?
https://manual.spirit-system.com/index. ... rn_to_Home
1.3.2 On (2)
Channel value -100% - -62% : When On (2) is displayed the unit is in a programming mode which allow to overwrite current Home spot to the new with position at which the model currently is. Change will affect all Banks - if used. Please note that it will not work if model is flying or if GNSS signal is very weak.
1.3.3 On (3)
Channel value -61% - -38% : When On (3) is displayed the unit is in a programming mode which allow to overwrite current Home spot to the new with position at which the model currently is. Change will affect only active Bank - if Bank Switching is used. Please note that it will not work if model is flying or if GNSS signal is very weak. This feature can be used only with Bank Switching, because you can program Home position differently for each bank.
1.3.4 On (4)
Channel value 27% - 56% : When On (4) is displayed it mean that at this point Return to Home is engaged and model will move to your Take-Off position. Take-Off position is programmed automatically during each Take-Off. This mode can be used stright with no Home position programming.
TrueBuild
Habásek wrote:https://manual.spirit-system.com/index. ... rn_to_Home
In other-words, no need to delete because if Mode(4) is used Take Off is used!
Thanks.
