automatic rescue
Mischael
Hello ,
have problems with automatic rescue .
i am on latest firware 3.74 and defined stabi function channel 8 ,on stabi tab is automatic rescue choosen .
If i switch to rescue, the heli stays inverted if i was flying upside down.
Don't know it's the new firmware, or the geolink .
In the past ,it has turned to upright ,skids down after a defined delay .
Please help
thanks
Hello Mischael,
here the link for automatic rescue, maybe you have overlooked something -
It should flip over to "skids down" after short time, see description -
Link for automatic rescue: https://manual.spirit-system.com/index. ... Automatic)
I don't know if you have an GT because this is here necessary -
With geolink I have no clue because I have none.
I hope this helps anyway -
Best regards
Matthias
Mischael
Hello Mathias,
thanks for answering.
Have also an Gt2 (3) ,in the past they worked great.
Now playing around with Geolink ,channel for altitude limit was not assigned, and not activated in Geolink settings .
Found this in the manual:
3.1.1 Stabi function
By default all GeoLink features are engaged as soon as a Stabi function is active. For example if Coaxial or Rescue mode is engaged the GeoLink feature is engaged as well and complement operation of a Stabi function by acting simultaneously.
No word from how to disable, and what the recovery does .....
Assigned now an channel for altitude limit and hopes
that the recovery from Gt will used ,otherwise geolink will end as an doorstop .
Greetings Michael
franz88
you don't use stabi function
But you use the name of the function.
also if you want rescue automatic you use rescue automatic of the spirit gt.
Important
You activate one function at a time.
I have spirit gt and geolink v2 and rescue automatic of the spirit is very best.
Rescue automatic spirit gt it always works while the geolink It works 8 times out of 10.
Mischael
Hello ,
had assigned channel 8 to F Stabi function, and in stabi tab i choose rescue automatic ,in Geolink altitude limit was off .
But it worked like rescue acro .
What are your settings ?
if you select Stabi/Function to Rescue Automatic directly, then you have to set F: Stabi Function in the General - Channels and assign channel to it.
Other solution is to set Stabi/Function to Selected by Channel and then set F: Rescue Automatic in the General - Channels. Second solution has advantage that you can assign more functions in this way.
