OMP M4 max 85A esc will not calibrate.
gdzero
I'm building a new OMP M4 max. Everything is working as it should with the exception of the motor. I am not getting the beep tones required to calibrate the esc. The FBL initializes as it should but nothing from the motor. I am using a Spirit GT and a Radiomaster TX16s mkII transmitter. Any advice would be appreciated.
Please make sure that Throttle is connected at the AUX port and that Throttle is really assigned at the Channel 1 at the Spirit Settings.
Also make sure that Throttle frequency is set to default 60Hz.
Other possibility is that the ESC was programmed for other signal range. In that case it must be recalibrated or you can recalibrate Spirit for using this range.
Lowering Throttle - Range Min. to for example 1000us could help.
gdzero
Thank-you Zexx86. I'll give this a try.
