Setting SPIRIT GT (last V 3.7.4)
Jepelisa
Rx FrSky R-XRS S-Bus out. Transmitter FrSky ETHOS XE-S. Goblin Minicomet.
After put on with external 2s lipo connected in aux1 and Rx in RUD and Spirit GT connected with my Mac, I have assign:
Throttle: no assignment
Ail: 2 channel
Elevator: 3 channel
Rudder: 4 Channel
Gyro: 5 Channel
Pitch: 6 channel
Banks: 7 channel
After this in "diagnostic " all the movements are moving accordingly of radio sticks....except Throtlle.
In our manual (v3.7.4) I read: When a channel for Throttle function is assigned, throttle output from the unit can be obtained from the AUX position (expected AUX1 I on the unit i have AUX1 and AUX2) .
So I try to assign the throttle on channel 1 (last one free) but it is no possible.
Pls help me Jepelisa
I think you have to put your ESC-cable in Aux1 Port (Master) thats absolutelly necessary !
Put your external 2s lipo in Ch0 if you have really an Spirit GT - Ch0 is always free in most applications -
Use CH1 in channelasignment for throttle and put the Master-Cable from ESC in Aux1 then all will work -
Best regards
Matthias
Jepelisa
I did as indicated in your message, everything is now working. thank you
