Update strategie from 3.6.1 to current 3.7.4
Tragl
Dear team,
Current I stay on version 3.6.1 (Software and related firmware of spirit gt)
What is the correct way (or best practice) to update both software and related firmware?
- Every version step after another? (This would be my standard how-to)
- Only versions where the settings must be controlled?
Thank you for your experience in advance
Carsten
Here you can see step by step guide for updating Spirit unit:
https://manual.spirit-system.com/index. ... pirit_unit
Almost always it does not matter and you can go immediately to the latest version. Only when there is very big version difference it is needed to carefully check ChangeLogs and see what was changed and verify these parameters.
From 3.6.1 there are no big changes, but I recommend to check the new/updated parameters. Especially Rotation Rates.
Tragl
--> Fine, I did so :D
--> OK, I took a look at all parameters that you've especially referenced in every single update step (like rescue, rotation rates, ...)
Thank you for support & great work and have a nice week ahead
franz88
I also stayed version 3.6.5 and now I want to update to the latest version and I don't know if update directly to the latest or update one by one
Guide was updated to tell everyone you can update directly to the latest version:
Tragl
ZeXx86 wrote:Here you can see step by step guide for updating Spirit unit:
... but I recommend to check the new/updated parameters. ...
Thank you for clarifying the update procedure
Please see my post: https://www.spirit-system.com/phpBB3/vi ... =24&t=6513
