V4.0.0 Diagnostic Tab no Live View
davehour
Why can’t I see Diagnostic Tab with the Live View model?
Diagnostic Tab with Live View.
Actual Display.
Actual Display.
With very low resolution it is not displayed. It cant fit all at the display. But you can still find it at the Setup Wizard.
davehour
Ok thanks.
SpUDmONSTeR
If I enlarge the window so that I get the Live view, the program crashes as soon as I open the diagnostics tab. If I reduce it again so that the view is not displayed, the program runs without any problems
EricDP
I have a similar problem. Mine doesn't crash, but the live view doesn't show no matter how big I make the window. It's just a blank rectangle. Anything needed to enable it?
It might not work on computers with 32bit Windows version.
Can you check you are running 64bit or 32bit?
It is also displayed in the Configuraiton window of the Spirit Settings.
