Export Konfiguration-Parameters as PDF, CSV or by a viewer
Posted: Sun 20. Jul 2025 18:44:19
by Tragl
Dear Team,
Regarding the documentation at https://manual.spirit-system.com/index. ... pirit_unit and the requirement to “compare the configuration data before and after the update for consistency”:
How do you typically handle this? Do you take screenshots of every page of the application before each update? Unfortunately, I can't simply memorize all the settings.
It would be very helpful if the application could generate a PDF that lists all configurable parameters in a table format, showing their names and the corresponding values. This would make a before/after comparison much easier.
Even better would be an export to CSV format, as this would allow for automated comparison via spreadsheet software.
Apparently, there was once a viewer available at: http://4dsviewer.spirit-system.com/www/
Such a tool would also be a viable solution.
Thank you very much and best regards,
Carsten
Re: Export Konfiguration-Parameters as PDF, CSV or by a view
Posted: Sun 20. Jul 2025 18:55:57
by 10x
I think this would be a good idea, like the castle creations esc have...
