Good evening
setting the return height to 90m ( about high trees in the area ) the heli flies back to the lift off point ( mode 4 ).
As soon as the RTH is active the electronic of Spirit moves the TS and therefore the heli dives to about 30m height during the flight back.
As soon as the model is at the starting point it climbs up to the height stored in the Geolink setup RTH ?
Using different heights ( 75, 55, 45m ) results in the same behaviour.
Jeti DC-24 FW 4.0.0 / Spirit GTR FW 4.0.0 / GeoLink FW 1.4.1
Do you guys have similar effects ?
p-51d
Spirit GTR / GeoLink V2 RTH height
Hi Thomas
reading through the forum I can see that you must be very busy;
in any case i would appreciate a short message about the above mentioned matter.
( have trees in the area and the behaviour is a risk of crashing my heli )¨
Thank you very much
Kind Regards
Roland
Thank you very much
Kind Regards
Roland
