New DUPLEX 2.4EX Empfänger REX 6
Franky13
Hallo!
there is already a setting graphics for the new DUPLEX 2.4EX receiver REX6 and the Spirit with Jeti DS16?
Thanks!!!
There is nothing different with REX6 configuration regarding the unit.
But you can use telemetry sensors and the integration with our unit at the same time.
MarkT
Have you actually tried to use a REX6 yet?
Reason I ask is that you can't seem to use the 'Device Explorer' with the REX6 and using the Jetibox emulator with it does not seem to let you change anything on the EXT port.
You do not need to use Jetibox. You can configure it through the transmitter.
But you will need configuration file to make it possible.
You can get it from Jeti, yet it is not official at the moment.
MarkT
I have emailed Jeti already as without the .bin file it is impossible to properly change settings on the REX6.
It is crazy that they would release it to retail without providing the update really but hopefully they will not take long to resolve this.
Until I get the file though it means no way to properly use the REX6 with the Spirit.
MarkT
Excellent, thanks for the link.
So having updated the TX it seems that the only difference is that you can't change the function of the EXT port, that remains as 'JetiBox/Sensor' so you change E1 or E2 to EX BUS and connect the Jeti there?
Franky13
Hello!
How do I connect the new REX6 receiver correctly to the Spirit?
I have the Spirit but connected to Ext. ...!?
I still use the Unisens-E.
http://www.spirit-system.com/phpBB3/vie ... f=20&t=484
Bye,
Frank
MarkT
You need to use device manager on the TX to configure E1 or E2 on the REX6 for EXBus and connect the Spirit to that port, not to EXT.
On the Rex6 EXT is for sensor connection, only E1 and E2 can be changed to EXBus.
