I was playing with the new software version 4.00 R2, and changed the window scale to 2.5 x.
Unfortunately, now the window appears really big, as expected, but I cannot now move it sufficiently on my monitor to reset the scale, because that feature is below where I can see on the monitor.
I don't seem to be able to apply any other features to reduce this window and the bar at the top of the application window will not go further than top of screen! there are also no scroll bars, either! My screen resolution is at its highest, so I cannot make the window appear smaller that way either!
Help, please!
Andy
Scaling of 4.00R2 Screen is proving a challenge !
AndrewJohnHawes
Just thought I will need to totally erase at a higher level on the PC and then reinstall.
You have to remove file called .spirit-scale.cfg from Documents directory. Then it will be at default 1.0x.
AndrewJohnHawes
Thanks! I am feeling a bit stupid, sorry. Previously, even though I reloaded the file, it still reverted to this bigger scale.
I will erase that file when I have left work and am home.
Thank you again!
Andy
Thank you again!
Andy
