Programming switches?
AndrewJohnHawes
I have been trying to use 3-position switch 'LR' to give me 3 different stabilization values for e.g. 0%, 30% and 50%.
I only seem to be able to configure -30%, 0% and 50% using 'range' for top position at -30%, then middle gives me 0% and setting lower to 50%, but would like the upper position to give 0%, then middle (30%) and bottom (50%).
I am probably being extra stupid in missing something?
Andy
AndrewJohnHawes
Was this implemented yet in latest upgrade, that all channels can pe programmed?
AndrewJohnHawes
I seem to remember reading that there would be upgrades to allow switches to be programmed more completely in a "next upgrade", is this still intended at some time soon?
Also, this new Forum layout seems to take a bit longer to function than the old one!
Andy
Yes, following update will add function programming with curves. This will allow complex output depending on switch position.
For week we are under DDoS attack. This makes our servers slower. We are working on solution these days.
AndrewJohnHawes
Thank you very much, excellent to hear!
I look forward to that, eagerly!
Andy
