return to Home (Easy version)
TrueBuild
Hi, I am trying to setup the Easy version of return to home.
I have setup as stated in the Easy Example; and to test I am looking at the Spirit Channel Mapping screen to see if I get the state on(4) .
I can get the system to show on(2)or on(3) but never on(4)
The example says Active Position on for F: geolink return to home; in my case channel 10
My 2-state switch when active sets F (channel 10) to 40%)
What should the inactive value of the F(channel 10) be set to.
Or put another way what is the normal value of F channel when the transmitter is switched on?
Geolink return to home two state switch
normal setting of switch is Down what value should F channel be?
return home switch is moved UP F channel is 40%
2 Easy Example
Example setup is the easy way to set Return to Home for a practical usage. Whenever you need, you will only need to flip a switch on your radio. The model will return to a lift off position and will hover at around 30 meters. You can change Return Altitude to any level you wish.
2.1 Setup
1. Enable Return to Home in the GeoLink - Aid Tab.
2. Set F: GeoLink Return to Home function in the General - Channels window and select a free channel in your radio.
3. Set this channel also in your radio to a 2-state switch.
4. For active position of the channel limit the value in your radio to 40%.
By limiting the channel to 40% only Mode (4) is used. There no Home position is needed to set. It is programmed automatically during each lift off.
