[ Spirit Wave 1.0.25 update ]
Spirit Wave News are available also here at the forum now!
  • [SPIRITOS] User Interface was reworked for better visibility at the sun light.
  • [SPIRITOS] All Themes were updated.
  • [LANGUAGE] Spirit Wave is fully localized to French language from now. Big thanks to Regis DM!
  • [INPUT] All values can be inserted also from a Virtual Keyboard as alternative way. After selecting a parameter, simply press and hold finger in the middle of screen to show the keyboard.
  • [HOBBYWING V5] Fixed incorrect settings in the ESC Setup.
  • [SCORPION] Brand new ESC Setup interface for Scorpion ESCs! From now you can set your favorite Scorpion ESC directly from Wave. Settings and Wiring is identical as with our Scorpion telemetry guide. Spirit firmware 4.0.1 is required to make it work.
  • [IMAGE] Fixed image uploading through Spirit Remote web interface when file contained unexpected suffix in the name.
  • [WIZARD] Setup Wizard for Spirit Heli was updated to make Rudder End-point settings more strightforward.
  • [SOUND] Deadband for Potentiometer centering detection was increased.
  • [WIDGET] New widgets for Turbine ECU from Xicoy.
  • [TRANSLATION] Fixed Czech translation for GeoLink - Speed widget.
  • [TRANSLATION] Chinesee translation was heavily updated.
  • [MODEL] Adding Model name with '/' character is fixed.
  • [LOGGING] When switching model with enabled logging, it will turn off automatically.
  • [ALARMS] Fixed bug with Reporting names not showing up after Power up.
Your Spirit System Team
