[ Version 4.0.1 released! ]
Posted: Tue 16. Sep 2025 9:47:09
New version 4.0.1 released!
Fine-Tuning update with a major tweaks for all Spirit units is available now!
Changes are following:
IMPORTANT: If updating from V3.X.X or older firmware please make sure to read ChangeLog for V4.0.0.
NOTE: It is recommended to lower Advanced/Cyclic Feed Forward by 1 - 3 points. Otherwise Stick Response could be too agressive. Value 4 is suitable for the most pilots.
NOTE: It is recommended to set Expert/Pitchup Compensation to 1 for the first flight after update.
NOTE: It is recommended to set Expert/Swashplate - Dampening to 10 for the first flight after update.
Big thanks to Timo Wendtland for extensive support and testing!
- Pitchup Compensation algorithm:
- Pitchup Compensation was enhanced to compensate pitch deflections more precisely during pitch pumping.
- We recommend to set Pitchup Compensation to 1 and start from there. Too High value could induce Aileron oscillations.
- Cyclic Gain tuning:
- Cyclic Gain has no impact on steering response anymore.
- Stick Response latency with a higher Gains was decreased to achieve as direct feeling as possible.
- Cyclic Feed Forward can be decreased.
- Cyclic Feed Forward tuning:
- Because of Cyclic Gain change it is possible to reduce Cyclic Feed Forward noticeable without loosing quick response.
- Default Cyclic Feed Forward is 4 now.
- Rudder Automatic Centering:
- From now rudder will be automatically centered even if Head Lock mode is active.
- Centering is very slow and will happen only if no model motion is detected.
- Automatic centering will help pilots to safely lift off in case they forgot to check the tail.
- New Swashplate - Dampening algorithm:
- This parameter can greatly improve stopping performance.
- Higher value will increase Integral Decay rate for Cyclic.
- Higher value will allow faster and cleaner Stopping, mainly for Elevator axis.
- Too high value (40+) could reduce Hovering stability.
- Default value was changed to 10.
- New Rudder - Smoothing algorithm:
- Smoothing algorithm was reworked for improved stopping with a Low RPM.
- Receiver Data Processing:
- Swashplate and Tail control has new algorithms that are extrapolating Input for all radio connections running at a slower Frame Rate than Servos. This will make all movements smoother.
- Collective Pitch control has no visible steps and servos will move cleaner.
- Elevator Filter:
- Elevator Filter has additional Derivative bandwidth filtration from the Motion Sensor.
- This can noticeable reduce Servo Load, Temperature and Consumption.
- Rudder Delay parameter:
- Effect of Rudder Delay was lowered little bit to reduce Servo Load.
- Additional filter was added for further reducing Servo Load and Servo Temperature.
- Spirit Settings software:
- Gyro Gain between Spirit Wave and Spirit Settings software was equalized.
- Fixed unstable connection with Wifi-Link on Mac.
- Motion Sensor Filter:
- New Strong option for the sensor filtration.
- Suitable for models with extremely high vibrations where Standard and Low Latency option can't work.
- Available for Spirit GT, GTR and W1 units.
- YGE ESC Setup support:
- Compatibility with the latest YGE ESC firmware was fixed.
- The ESC will work out of the box with full Telemetry and Integration support when using Spirit Wave radio.
- New Scorpion ESC Setup support:
- From now all Scorpion Tribunus ESC can be directly configured through Spirit Wave radio.
- Wiring require no change from Scorpion ESC guide. Only Telem UNI cable is required to make it work.
- Make sure that Spirit Wave is updated to the latest 1.0.25+ firmware.
- Scorpion ESC telemetry:
- Setpoint and PWM telemetry variables are available for Spirit Wave.
- XDFly/ZTW/OMP ESC Telemetry:
- Current and Capacity measurement correction.
- XDFly manual guide was separated to a new one: XDFly Guide
- JETI Telemetry support:
- Added support for all JETI sensors, thanks to JETI Model! The sensors will use ESC Telemetry and GeoLink variables, depending on a Sensor type.
- From now you can connect JETI sensors directly with the Spirit unit, allowing main variables to be displayed.
- If some sensor is not support natively, it will automatically detect variables. Detection could take several seconds.
- Wiring require Telem UNI cable (at the SAT1 port), while sensor itself has to be powered from BEC.
- F-BUS protocol:
- Compatibility and Speed with F-BUS receivers was improved.
- GeoLink Return To Home function:
- Automatic Home programming for Mode (4) was updated to update Lift Off position when Throttle curve is under 25%.
- This will help Nitro/Gasser pilots to safely return model to a true Lift Off position.
- Even that motor is idling it is able to save the position.
- Tandem Helicopter:
- Tandem Helicopter support was improved for better stability and precision in flight.
- Spirit RX protocol:
- When Clearing the logs remotely Mounting Position could be unexpectedly reconfigured with some units!
- Base parameters such as Swashplate Type and Mounting Position can be reconfigured only with Throttle turned off for safety reasons.
- Highly recommended to update to avoid this issue.
