Altitude Limit not working (It now works thanks to help from Mona)
TrueBuild
I cannot get Altitude Limit working; I have set altitude to 4 min and 10 metres.
Geo-Link settings says Altitude Limit is Ticked and low is set to 4 and high is set to 10, Triggering Acceleration is set to 4.
Diagnostics tab shows GeoLink enabled
F: Geo-Link Altitude Limit Channel 10 changes from central green bar to little green bar on left
Channel 10 on transmitter moves from 0 to 100%
The F: Geo-Link Altitude Limit State is Off at all times.
Mona
When you say "central green bar" do you mean it's halfway? Sounds like you are not getting full travel on the channel and it's possibly reversed too, in some transmitters the channel range is -100% to 100% instead of 0% to 100% so you could only be using half.
TrueBuild
Mona wrote: Thu 25. Sep 2025 16:39:30 When you say "central green bar" do you mean it's halfway? Sounds like you are not getting full travel on the channel and it's possibly reversed too, in some transmitters the channel range is -100% to 100% instead of 0% to 100% so you could only be using half.
Wow Thank you.
I now think I have it working :)
I did type a 3/4 of an hour blow by blow account of what I changed; but then I pressed some darn key on the keyboard and it all went :(
My only concern is what does f:GeoLink altitude limit state On (1) mean ?
Mona
On means it will use the maximum altitude set in the software, and the minimum altitude will be either the low limit setting (when any value above 0m is configured), or uses the current in-flight altitude (at the moment of enabling) as the low limit (when 0m is set in the software). This is explained in the manual: https://manual.spirit-system.com/index. ... tude_Limit
TrueBuild
Mona wrote: Fri 26. Sep 2025 12:15:28 On means it will use the maximum altitude set in the software, and the minimum altitude will be either the low limit setting (when any value above 0m is configured), or uses the current in-flight altitude (at the moment of enabling) as the low limit (when 0m is set in the software). This is explained in the manual: https://manual.spirit-system.com/index. ... tude_Limit
My bad.
I should have said what does the number 1 in the brackets mean.
Example...
The return to home (RTH) GeoLink mode On(4) the number four is a parameter that tells the system to use the detected take of point, as the RTH position.
So I wondering what, F:GeoLink altitude limit state On (1) meant?
Mona
Just how the states are numbered, for altitude limit there is only one On state (1), it has no other meaning. As you said for functions that have multiple On states such as RTH you can have different numbers depending on the channel value.
