Spirit GT, is this a correct behaviour?
Jack.S
I have done a setup on mine Spirit GT gyro and everything seems to work as expected but..
Upon startup of the spirit sytem the blades goes to 0 degree pitch and stay there even if pitch stick is at bottom, when I touch the throttle/pitch stick briefly they go to the programed pitch of - 12 degree as they should but this is only after touching the stick, after this pitch works normally,is this a correct behaviour?
Edit..
Default
Ok, finally everything seems to work as expected, no strange pitch behaviour upon initilaizing, in diagnostics tab all values 100 or 99 in both directions, have managed to set upp the banks 0/1/2 with..
flightmode 0/Bank 0 (stabi disabled)
Flightmode 1/Bank 1(stabi normal)
Flightmode 2/Bank 2(stabi coaxial)
Everything reacts normally in the software upon switching banks
I just have one more question..
I noticed that when channel 5 is unassigned in the channels window the rudder gain is controlled by the software in all three banks but i also noticed that when channel 5 is assigned to the gyro rudder gain im able to control the gain from the transmitter and in this case the rudder gain is disabled in the software...do I have the option to choose this or Im I stuck to the software gain control?
Cheers
Jack
Best R
/Jack
Not correct behavior.
Channels are probably mapped incorrectly or there is wrong radio settings.
I recommend to check Diagnostic tab first. Is Pitch channel moving there all the time even when it is locked?
Jack.S
In diagnostics tab nothing is movin upon I move the sticks and everything moves in right direction, I have done a wizard setup with goblin 770 as preset.it seems to me when gyro is starting up it positions the pitch about 0 degress even with stick in the bottom, when touching throttle stick the pitch lowers to normal stick position, in my case -12 degrees.
Im running standard pwm reciver.
Br
Jack
Jack.S
Ok, small update..
In the pitch range settings iI had tuned in -12/+12...
Since I am a scale flyer I dont need that huge amount of negative pitch and it was when I was begining to tune down the negative pitch I noticed following
In my radio I had a linear pitch curve -100/+100, tuning the curve from -100 to -80 nothing happened, the originally pitch of -12 was still there, when I reached -70 the -pitch started to change on the blades and when I got to about -40 I got the desired pitch of -6,5 for my scaler and also the behaviour with the swashplate stopped, now when the gyro starts up it initializes normally and I dont have to touch the stick do get a normal stick pitch, can you please comment this thomas, it seems that is something with the pitch curve in mine fly sky paladin ultra that was causing this behaviour but now it seems to work normally, I have several microbeast ultra connected to this radio and even with a pitch curve of -100/+100 I didnt get this behaviour.
Cheers
Jack
Jack.S
Problem solved, some values in diagnostics where extended and that problem is fixed
Im my transmitter when adjisting the end points its inpossibble to get exactly 100 om some values, either I get 100 on lower value and 99 on higer, when adjusting it goes up from 99 to101, is it better with 99 or should I go for 101?
Cheers
Jack
Jack.S
Cheers
Jack
