Governor does not leave spool up phase
Zwein
I am running the following setup:
- Goblin Raw 700 Nitro with OS105
- XGuard Backplate RPM Sensor V2
- Spirit GTR (SW: 4.0.1)
I tried my first flight with the spirit Governor after setting everything up as described in the manual but I seemingly couldn't get the governor to engage fully, even after smooth spool up to the desired RPM.
The RPM value in the Jeti telemetry seems plausible (regarding sensor signal, sensing divider and gear ratio).
So my question is what has to be present for the Governor to switch from spool up procedure to fully engaged mode?
Thank you for your help.
Greetings
Sven
it is needed to make sure Governor is enabled (preferably in each bank if using Bank Switching).
Then it is needed to set at least 50% as throttle curve. And the curve must be flat line.
This will also use smooth spoolup rampup.
