GeoLink problem
régis10300
Honestly, this new version is really not a success. After a module that was impossible to put back into service, I’ve just realized that GeoLink does not work for trace tracking. When I tried to check the F3C flight lines from my last flights, nothing was recorded.
With the return-to-home engaging with extreme force and in a random direction, I’m starting to be very disappointed with this module. It has become far too complicated, and we are forced to install updates even when we don’t want to (personally, I only do updates when they bring something new; otherwise, I don’t).
Disappointed, really disappointed…
Are you reading the manual?
https://manual.spirit-system.com/index. ... nk_Logging
Otherwise you would know that everything works OK.
Yes, returning home would require a setting for the forces in the future to quickly take over the collective - for scale heli and airplane.
It probably doesn't matter how the model returns, when it returns you will align it to the position you need.
Updates always bring something new or fix some previous bugs.
first from all I am sure that problem is in your settings.
You shipped us Spirit unit that was not working at all according you. After inspection it was working perfectly correct.
Additionally GeoLink had no update for over year. We absolutely do not push anyone to install any update. There are pilots with version 1 that is 16 years old.
If your post shpuld tell us how you ate disappointed, we are going to remove it.
