Spirit gt dead
Mattia nanni
I've had a Spirit gt for a few months and I've been using it on two electric helicopters, I'm fine with the spirit, then I decided to mount it on my gasoline-powered Vario aircrane, I did 3 hovering but the vibrations are high, after those three flights the control unit seems crazy, as soon as you turn it on everything is ok... then as soon as I move ailetons or lift the plate no longer levels, also if you give the servo controls I don't respond simultaneously, example: maybe two move and one moves very little, if I turn off the power and reattach it back to normal, until the next time I move the cyclic stick, there is no active rescue/leveling function, I tried to reset but nothing, now it's mounted on an Align tb60, thinking that the problem was only the vibrations, instead I also do it with that now,
